11 years agoVGA monitor
Hi guys. I am trying to connect altera de2-115 board with VGA monitor. My coding was sucessful with no error. But, I have problem when downloaded the coding into fpga. Here is the problem (att...
11 years agoHi Tricky.
Here is the code. Thanks. library ieee; use ieee.std_logic_1164.all; entity vga_test is port( clk, reset: in std_logic; sw: in std_logic_vector(2 downto 0); hsync, vsync, comp_sync: out std_logic; rgb: out std_logic_vector(2 downto 0)); end vga_test; architecture arch of vga_test is signal rgb_reg: std_logic_vector(2 downto 0); signal video_on: std_logic; begin -- instantiate VGA sync circuit vga_sync_unit: entity work.vga_sync port map(clk=>clk, reset=>reset, hsync=>hsync, vsync=>vsync, comp_sync=>comp_sync, video_on=>video_on, p_tick=>open, pixel_x=>open, pixel_y=>open); process(clk, reset) -- rgb buffer begin if (reset = '1') then rgb_reg <= (others => '0'); elsif (clk' event and clk = '1') then rgb_reg <= sw; end if; end process; rgb <= rgb_reg when video_on = '1' else "000"; end arch;
