10 years agoVersion Control Files for Altera IP
I am using Quartus 16.0 and would like to only store in version control the necessary files needed for Altera IP (this includes files for simulation). I tried only storing the .QSYS and .SOPCINFO fi...
10 years agoHi kendallogic,
for IP simulation you need some device libs (altera_mf, altera_primitives, ...) and the IP model. It should be sufficient to version control the model source files. I'm using UniPhy IP for DDR3 RAM. The simulation model for the DDR3 controller must explicit generated with megawizard (generation option). For IP simulation a msim_setup.tcl is generated. You see in the tcl file under alias "com" which files are needed for simulation. Jens
