11 years agoVerliog - & and | operations backwards?
I am learning Verilog and at a stage in which I would like to see some results from my dev board. I have started with a very simple program which takes two inputs and uses the "&" function to outp...
11 years ago --- Quote Start --- Check to see if the LEDs are active low. Thats usually the problem --- Quote End --- Thank you for the reply. The problem that I am having is that when I use the "&" operator the truth table that I get is for an "or" gate and vice versa when I use the "|" operator. (also my LED is active when it has a high input)
