16 years agoVerilog: is else statement mandatory
I'm reviewing a program written by another developer, and have noticed that they frequently leave out the final else in if/else statements, nor do they always assign values to all variables from one ...
16 years ago --- Quote Start --- Is there anything strictly dangerous about doing so in Quartus Verilog? Is is free to treat unspecified variables as "DON'T CARE", or will it enforce that the value not change? --- Quote End --- It will enforce a no change. We are all assuming this is part of a synchronous clocked process. If so, then this is ok in most cases. If it is combinatorial logic, then it might be dangerous because it would normally produce an async latch. --- Quote Start --- In both cases, the synthesis tool has to decide whether to implement the combinatorial logic as a clock enable (if the device has such a thing) or as an always enabled register with feedback from the register output. --- Quote End --- I read this paragraph, and it sounds a bit misleading to me. In most modern ASIC technologies, both things are actually the same. In other words, clock enable is usually implemented as a mux with the register feedback. When talking about an FPGA, matters are different. e.g., in most Altera families, the clock enable is a LAB wide signal. Then both synthesis methods, clock enable or LUT based mux, are indeed different.
