12 years agoverilog code for SINE PWM
Hello friends.. I am trying to write verilog code for sine pwm. please check the below code and tell whether it will work or not. thank you.
module sine_cos(clock, reset, en, sine, cos); input clock, reset, en; output [7:0] sine,cos; reg [7:0] sine_r, cos_r; assign sine = sine_r + {cos_r[7], cos_r[7], cos_r[7], cos_r[7:3]}; assign cos = cos_r - {sine[7], sine[7], sine[7], sine[7:3]}; always@(posedge clock or negedge reset) begin if (!reset) begin sine_r <= 0; cos_r <= 120; end else begin if (en) begin sine_r <= sine; cos_r <= cos; end end end endmodule module triangle(clock, reset, triangle); input clock, reset; output[7:0] triangle; reg[7:0] triangle; reg[7:0] counter; reg[7:0] updown; always@(posedge clock or negedge reset) begin if(reset) begin counter <= -125; updown <= 0; end else if (rising_edge(clock)) begin if (updown == 0) if (counter < 125) begin counter <= counter + 5; end if (counter == 120) begin updown <= 1; end else if (updown == 1) if (counter >-125) begin counter <= counter - 5; end if (counter == -120) begin updown <= 0; end end end always@(posedge clock or negedge reset) begin if(reset) begin triangle <= counter; end end endmodule module PWM(triangle, cos, pwm, clock); input triangle, cos, clock; output pwm; reg pwm; reg [15:0] counter = 0; always @ (posedge clock) begin if (cos >= triangle) pwm = 1; else pwm = 0; end endmodule
