vcom-1576
The simulation flow progress shows these errors :
# ** Error: Waveform.vwf.vht(32): near "-": (vcom-1576) expecting IS.
# ** Error: C:/intelFPGA_lite/20.1/modelsim_ase/win32aloem/vcom failed.
The code below is from the simulation settings (VHDL):-
onerror {exit -code 1}
vlib work
vcom -work work Lab2-2.vho
vcom -work work Waveform.vwf.vht
vsim -novopt -c -t 1ps -L cyclonev -L altera -L altera_mf -L 220model -L sgate -L altera_lnsim work.Lab2-2_vhd_vec_tst
vcd file -direction Lab2-2.msim.vcd
vcd add -internal Lab2-2_vhd_vec_tst/*
vcd add -internal Lab2-2_vhd_vec_tst/i1/*
proc simTimestamp {} {
echo "Simulation time: $::now ps"
if { [string equal running [runStatus]] } {
after 2500 simTimestamp
run -all
quit -f
- SyafieqS
Hi Khassib,
In your .vhd file, you probably need to look at the line pointed 32. Modelsim is telling that it expects IS probably related to identifier/syntax. Snippet of the code would be helpful here.
- SyafieqS
We do not receive any response from you to the previous reply that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
