RogerJL
5 years ago(vcom-1105) Name (indexed name) does not denote an entity name.
Finally tracked down why I get this from modelsim-altera when using
Run Simulation Tool -> RTL Simulation
The generated PROJECT_run_msim_rtl_vhdl.do is not generated in correct order
fil...
Nurina
5 years agoHi,
I can raise this issue to engineering and see if they can do anything about it.
Can you let me know which version of Quartus you're using and which device you're synthesizing the code on?
Thanks!
Nurina
