RogerJL
5 years ago(vcom-1105) Name (indexed name) does not denote an entity name.
Finally tracked down why I get this from modelsim-altera when using
Run Simulation Tool -> RTL Simulation
The generated PROJECT_run_msim_rtl_vhdl.do is not generated in correct order
fil...
RogerJL
5 years agoYes, swap the compile order of the two files.
This issue with a simple work around took me hours, checked every setting I could find...
It just did not cross my mind that the tools did not generate compiling code.
I would really like to be able to use NativeLink, especially important as when I am done with my editions someone else might pick this project up and expect NativeLink to work out of the box - repeating my mistakes...
