RogerJL
5 years ago(vcom-1105) Name (indexed name) does not denote an entity name.
Finally tracked down why I get this from modelsim-altera when using
Run Simulation Tool -> RTL Simulation
The generated PROJECT_run_msim_rtl_vhdl.do is not generated in correct order
fil...
Nurina
5 years agoHi,
By swapping the compile order, do you mean editing the .do file thus using a scripted simulation flow instead of NativeLink? If so, I do think that's the only workaround for your problem unfortunately.
Nurina
