11 years agoVCCIO compatiblity issue with "new" MAX10 project
I am currently working my way through the NIOS II hardware tutorial project. I unzipped the file and ran through the tutorial. The tutorial is a basic NIOS II processor with only two external I/O's. ...
hansfbaier
5 years agoThese lines in the .qsf file should fix the problem:
# disable config pin so bank8 can use 1.2V
set_global_assignment -name AUTO_RESTART_CONFIGURATION ON
set_global_assignment -name ENABLE_CONFIGURATION_PINS OFF
set_global_assignment -name ENABLE_BOOT_SEL_PIN OFF
