11 years agoVCCIO compatiblity issue with "new" MAX10 project
I am currently working my way through the NIOS II hardware tutorial project. I unzipped the file and ran through the tutorial. The tutorial is a basic NIOS II processor with only two external I/O's. ...
11 years agoset_global_assignment -name FAMILY "MAX 10"
set_global_assignment -name DEVICE 10M50DAF484C8GES set_global_assignment -name TOP_LEVEL_ENTITY niosII_create_hw_dev_tutorial set_global_assignment -name ORIGINAL_QUARTUS_VERSION 15.0.0 set_global_assignment -name PROJECT_CREATION_TIME_DATE "22:04:25 AUGUST 26, 2015" set_global_assignment -name LAST_QUARTUS_VERSION 15.0.0 set_global_assignment -name QIP_FILE qsys1/synthesis/niosII.qip set_global_assignment -name BDF_FILE nios2_quartus2_project.bdf set_global_assignment -name PROJECT_OUTPUT_DIRECTORY output_files set_global_assignment -name MIN_CORE_JUNCTION_TEMP 0 set_global_assignment -name MAX_CORE_JUNCTION_TEMP 85 set_global_assignment -name DEVICE_FILTER_PIN_COUNT 484 set_global_assignment -name DEVICE_FILTER_SPEED_GRADE 8 set_global_assignment -name ERROR_CHECK_FREQUENCY_DIVISOR 256 set_global_assignment -name EDA_SIMULATION_TOOL "ModelSim-Altera (VHDL)" set_global_assignment -name EDA_OUTPUT_DATA_FORMAT VHDL -section_id eda_simulation set_global_assignment -name STRATIX_DEVICE_IO_STANDARD "2.5 V" set_global_assignment -name BDF_FILE niosII_create_hw_dev_tutorial.bdf set_global_assignment -name PARTITION_NETLIST_TYPE SOURCE -section_id Top set_global_assignment -name PARTITION_FITTER_PRESERVATION_LEVEL PLACEMENT_AND_ROUTING -section_id Top set_global_assignment -name PARTITION_COLOR 16764057 -section_id Top set_global_assignment -name IOBANK_VCCIO 1.2V -section_id 8 set_location_assignment PIN_C5 -to LED[7] set_location_assignment PIN_C7 -to LED[0] set_location_assignment PIN_B4 -to LED[6] set_location_assignment PIN_A5 -to LED[5] set_location_assignment PIN_C4 -to LED[4] set_location_assignment PIN_B7 -to LED[3] set_location_assignment PIN_A6 -to LED[2] set_location_assignment PIN_C8 -to LED[1] set_location_assignment PIN_M8 -to MAX10_CLK1_50 set_instance_assignment -name IO_STANDARD "1.2 V" -to LED[7] set_instance_assignment -name IO_STANDARD "1.2 V" -to LED[6] set_instance_assignment -name IO_STANDARD "1.2 V" -to LED[5] set_instance_assignment -name IO_STANDARD "1.2 V" -to LED[4] set_instance_assignment -name IO_STANDARD "1.2 V" -to LED[3] set_instance_assignment -name IO_STANDARD "1.2 V" -to LED[2] set_instance_assignment -name IO_STANDARD "1.2 V" -to LED[1] set_instance_assignment -name IO_STANDARD "1.2 V" -to LED[0] set_global_assignment -name ENABLE_OCT_DONE ON set_global_assignment -name EXTERNAL_FLASH_FALLBACK_ADDRESS 00000000 set_global_assignment -name USE_CONFIGURATION_DEVICE OFF set_global_assignment -name CRC_ERROR_OPEN_DRAIN OFF set_global_assignment -name FORCE_CONFIGURATION_VCCIO ON set_global_assignment -name OUTPUT_IO_TIMING_NEAR_END_VMEAS "HALF VCCIO" -rise set_global_assignment -name OUTPUT_IO_TIMING_NEAR_END_VMEAS "HALF VCCIO" -fall set_global_assignment -name OUTPUT_IO_TIMING_FAR_END_VMEAS "HALF SIGNAL SWING" -rise set_global_assignment -name OUTPUT_IO_TIMING_FAR_END_VMEAS "HALF SIGNAL SWING" -fall set_instance_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top
