14 years agoThanks.
That example is a way I thought maybe would do what I need. I don't know how, but I need to do something like this: for i in 1 to 64 (increment by 8: i.e. 0, 8, 16...) label_01: test PORT MAP (inpp(a, a), outpp(a, a)); end for; OR I could do this: label_01: test PORT MAP (inpp(1, 1), outpp(1, 1)); label_02: test PORT MAP (inpp(8, 8), outpp(8, 8)); label_03: test PORT MAP (inpp(16, 16), outpp(16, 16)); But is too many times i must call the component, let's say 4096. So it's not possible do this way. It's for image processing. I need to divide an image in 8x8 blocks. And put every individual block in a component If someone have some idea. Thank you
