8 years agoUtilize M10k Memory block
Hi, I have compiled my kernel and i know only uses 16% of the M10k memory. Is there way i can use more of it? Also, i view my report, it says "loop sacrificed fmax to achieve II to 1." Bu...
8 years agoHi HRZ,The programming guide quote "You cannot use the library function malloc or the operator new to allocate physically shared memory.". So, can i realloc the buffer? The thing is i want to resize the output buffer.
data_buffer = clCreateBuffer(context, CL_MEM_ALLOC_HOST_PTR, buffer_size, NULL, &status); //initiate
// clEnqueueTask // some process
x = clEnqueueMapBuffer(queue,data_buffer,CL_TRUE,CL_MAP_WRITE | CL_MAP_READ,0,size*sizeof(float),0,NULL,NULL,&status); //read output
if(something) x = realloc(x, newsize*sizeof(float) //realloc new size to the output buffer
else //take back old size
