12 years agoUsing the SDRAM Controller with Qsys
I am trying to use Eclipse to program an application using the lcd. My qsys system uses an sdram controller. I receive a single error in the alt_main.c which was generated in the bsp. The error...
10 years agoHello all,
This code has been tested with the BeMicroMax and it will be help you to test your SDRAM memory : We assume that you are set your memory controller with QSYS : In my case the memory controller is mapped at the address : (0x800000)# define SDRAM_BASE (0x800000)# define SDRAM_BASE_MUX (SDRAM_BASE + 0x2000) /** Offset for the exception */ /** Variables */ uint32_t u32AddrSram = 0; uint16_t u16Value = 0; uint16_t u16ReadSramValue = 0; /** example for write and read only one byte at the time in the sram */ for( u32AddrSram = 0; u32AddrSram< 100 ; u32addrsram += 0x08) { /** Write Data */ alt_printf("\n*** SDRAM WRITE[%x] VALUE = %x \n\r ", (SDRAM_BASE_MUX + u32AddrSram) , (uint8_t)(u16Value)); iowr_8direct(SDRAM_BASE_MUX, (uint16_t)u32AddrSram, (uint8_t)u16Value); /** Read Data */ u16ReadSramValue = iord_8direct(SDRAM_BASE_MUX, u32AddrSram); alt_printf("\n*** SDRAM READ[%x] VALUE = %x \n\r ", (SDRAM_BASE_MUX + u32AddrSram), u16ReadSramValue); /** Change the value */ u16Value++; } /** example for write and read only 2bytes at the time in the sram */ u16Value = 0xA000; for( u32AddrSram = 0; u32AddrSram< 100 ; u32addrsram += 0x10) { /** Write Data */ alt_printf("\n*** SDRAM WRITE[%x] VALUE = %x \n\r ", (SDRAM_BASE_MUX + u32AddrSram) , (uint16_t)(u16Value)); iowr_16direct(SDRAM_BASE_MUX, (uint16_t)u32AddrSram, (uint16_t)u16Value); /** Read Data */ u16ReadSramValue = iord_16direct(SDRAM_BASE_MUX, u32AddrSram); alt_printf("\n*** SDRAM READ[%x] VALUE = %x \n\r ", (SDRAM_BASE_MUX + u32AddrSram), u16ReadSramValue); /** Change the value */ u16Value++; } /*** Result for Byte */ *** SDRAM WRITE[802000] VALUE = 0 *** SDRAM READ[802000] VALUE = 0 *** SDRAM WRITE[802008] VALUE = 1 *** SDRAM READ[802008] VALUE = 1 *** SDRAM WRITE[802010] VALUE = 2 *** SDRAM READ[802010] VALUE = 2 *** SDRAM WRITE[802018] VALUE = 3 *** SDRAM READ[802018] VALUE = 3 *** SDRAM WRITE[802020] VALUE = 4 *** SDRAM READ[802020] VALUE = 4 *** SDRAM WRITE[802028] VALUE = 5 *** SDRAM READ[802028] VALUE = 5 *** SDRAM WRITE[802030] VALUE = 6 *** SDRAM READ[802030] VALUE = 6 *** SDRAM WRITE[802038] VALUE = 7 *** SDRAM READ[802038] VALUE = 7 *** SDRAM WRITE[802040] VALUE = 8 *** SDRAM READ[802040] VALUE = 8 *** SDRAM WRITE[802048] VALUE = 9 *** SDRAM READ[802048] VALUE = 9 *** SDRAM WRITE[802050] VALUE = a *** SDRAM READ[802050] VALUE = a *** SDRAM WRITE[802058] VALUE = b *** SDRAM READ[802058] VALUE = b *** SDRAM WRITE[802060] VALUE = c *** SDRAM READ[802060] VALUE = c /** result for 2bytes read */ *** SDRAM WRITE[802000] VALUE = a000 *** SDRAM READ[802000] VALUE = a000 *** SDRAM WRITE[802010] VALUE = a001 *** SDRAM READ[802010] VALUE = a001 *** SDRAM WRITE[802020] VALUE = a002 *** SDRAM READ[802020] VALUE = a002 *** SDRAM WRITE[802030] VALUE = a003 *** SDRAM READ[802030] VALUE = a003 *** SDRAM WRITE[802040] VALUE = a004 *** SDRAM READ[802040] VALUE = a004 *** SDRAM WRITE[802050] VALUE = a005 *** SDRAM READ[802050] VALUE = a005 *** SDRAM WRITE[802060] VALUE = a006 *** SDRAM READ[802060] VALUE = a006
