12 years agoUsing the SDRAM Controller with Qsys
I am trying to use Eclipse to program an application using the lcd. My qsys system uses an sdram controller. I receive a single error in the alt_main.c which was generated in the bsp. The error...
12 years agoHi,
It seems that the problem isn't the SDRAM controller, Rather, make sure that the c file containing your "main" is correctly added to your project. Check the following line in the Makefile of your project : # Paths to C, C++, and assembly source files. C_SRCS := ... regards,
