Using simulation grammar in verilog file
- 5 years ago
OK so your version of Quartus supports Verilog-1995 and Verilog-2001. The system tasks you're using is that of SystemVerilog-2009. You should try replacing $error() with $display(). Make sure you set Verilog HDL Input to Verilog-2001 in the Compiler Settings.
More information on Verilog-2001 system tasks can be found here in clause 17: https://ieeexplore.ieee.org/document/954909
Nurina
Nurina
Thank you very much
