10 years agoUsing: set_global_assignment -name QIP_FILE in .tcl script fails
Title says it all really. I have a setup that requires the use of environment variables when setting these kind of assignments. Most seem to work, but when it comes to QIP_FILE assignments in a...
10 years agoYou shouldn't need the full path to your qip file. The command line tools use the connected directory as the starting point. If you run your script while connected to your top level project directory it should work fine.
