16 years ago
Using RAM on Cyclone 3
Hi all,
I am using a Cyclone 3 FPGA (EP3C16F256) and I want to use it's RAM. I am not familiar with internal RAM on FPGAs, I was going to write it myself as an array but then I found out that it has a internal RAM. Could anyone give me a quick guide about using that RAM?
Dvido
    So the synthesizer will determine automatically whether to put the array that I wrote as RAM? I don't need to define anything special?
    Aslong as you follow the general coding guidlines, yes
    http://www.altera.com/literature/hb/qts/qts_qii51007.pdf
    I dont know anything about verilog, but I know in VHDL Quartus will also let you use arrays of types other than std_logic_vector to infer rams from, including signed/unsigned and integer (thats given a limiting range), and fixed point types in the new IEEE floatfixlib.
    As another point - I think its much better using arrays anyway as its a bit more clear whats going on than connecting signals into a port map!
    A shortcut to learn the RAM inference syntax is to use the respective VHDL templates offered by the Quartus editor context menu.
