10 years agoUsing Quartus with 4k diaplays
Hello, The schematics on 4K displays are corrupted (please, see snapshot in attachment). Does exist some workaround ? Thanks in advance. Pavel
10 years ago --- Quote Start --- I've just tried it. Nothing changed ... although I didn't add registry key. Can you suggest me the name and value. Thanks. --- Quote End --- All right, back home. The following is my reference and has a good instruction set and includes the below for the registry key to use: http://winaero.com/blog/how-to-fix-apps-that-look-small-on-high-dpi-and-high-resolution-displays/:
- Open Registry Editor (Regedit.exe) in Windows 8.1 or Windows 10. Navigate to the following registry subkey: HKEY_LOCAL_MACHINE > SOFTWARE > Microsoft > Windows > CurrentVersion > SideBySidehttp://winaero.com/blog/wp-content/uploads/2016/02/dpi3-600x279.png (http://winaero.com/blog/wp-content/uploads/2016/02/dpi3.png)
- Right-click, select NEW > DWORD (32 bit) Value. Give it a name: PreferExternalManifest, and then press ENTER.
- Right-click PreferExternalManifest, and then click Modify. Enter Value Data 1. Click OK. Exit Registry Editor.
- Now restart Windows and run the app for which you added this manifest.
