Altera_ForumHonored Contributor15 years agoUsing Modelsim-Altera as the simulation tool I tried to use Modelsim-Altera 6.3g_p1 as the simulation tool for Quartus|| 8.1 web edition. I followed the instructions as available from Altera website. The problem I'm facing is that it works fine...Show More
Altera_ForumHonored Contributor15 years agoyou'll need to post some code to see how you are trying to use it.
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
