8 years agoUsing JTAG programmer with time limited evaluation IP license
Hi, I'm having some trouble programming my design using JTAG - specifically I cannot program my board with a time limited .SOF. I've tried this in SignalTap II firstly, which fails with "JTAG C...
8 years ago --- Quote Start --- Apologies for lack of info - Quartus Prime Pro 16.1 - the IP being used is the Altera/Intel Tri-speed Ethernet MAC. Here is the most recent PDF for it: https://www.altera.com/en_us/pdfs/literature/ug/ug_ethernet.pdf Thanks for taking a look --- Quote End --- Also, the device I'm using is an Arria 10AX115S2F45I2SGES. After attempting a configuration via cmd instead of Quartus GUI, I got error message 209014 - CONF_DONE pin failed to go high in device 1. I checked altera records for this error, and this relates to either cables being not plugged in (not applicable to my case, as I can configure just fine with a .sof that doesn't include the time-evaluation module). Other causes include a bug in Quartus versions earlier than 16.1.1 for MAX 10 chips - I am on v16.1.0 but am using an Arria10, not a MAX 10. I've checked the CONF_DONE pin for my FPGA, which is PIN_AP27, which I haven't constrained, so I don't think I'd be having an issue there either.
