11 years agousing 24mhz on board oscillator clock on bemicro CV board
Hi I am using BeMicro CV board for a simple demo . My design uses the 24Mhz clock which is present on board . The reference guide mentions this to be at pin M9. Using quartus software ...
11 years ago --- Quote Start --- Minor point but those constraints are found in the Quartus Settings File (qsf), rather than the qsys file. It does sound like there's a possible board fault. However, this oscillator source is also used by the on-board USB-Blaster. Does that work or are you using the JTAG chain header to program the FPGA? Try driving the clock out of one of the pins in a user header. In your code simply 'assign' a spare I/O pin, that goes to the header, the 24MHz clock. Cheers, Alex --- Quote End --- Hi Alex I meant the qsf file not qsys, my bad. You are right since it is shared by the USB blaster and I have used that to program the board , clk has to be working, unless something is wrong with the trace connecting it to the cyclone FPGA. I used the .jic file to program the board, does it use a different clk? I tried assigning the clk to one of the header pins but the synthesis tool warns that the debug clock output is tied to a zero. Something like: input clk; output dbg_clk; assign dbg_clk = clk; I am thinking this means that the tool just optimized it out? How can I avoid this?
