11 years agousing 24mhz on board oscillator clock on bemicro CV board
Hi I am using BeMicro CV board for a simple demo . My design uses the 24Mhz clock which is present on board . The reference guide mentions this to be at pin M9. Using quartus software ...
11 years agoMinor point but those constraints are found in the Quartus Settings File (qsf), rather than the qsys file.
It does sound like there's a possible board fault. However, this oscillator source is also used by the on-board USB-Blaster. Does that work or are you using the JTAG chain header to program the FPGA? Try driving the clock out of one of the pins in a user header. In your code simply 'assign' a spare I/O pin, that goes to the header, the 24MHz clock. Cheers, Alex
