11 years agousing 24mhz on board oscillator clock on bemicro CV board
Hi I am using BeMicro CV board for a simple demo . My design uses the 24Mhz clock which is present on board . The reference guide mentions this to be at pin M9. Using quartus software ...
11 years ago --- Quote Start --- when I power up the board I do not see any clock going into the design --- Quote End --- Do you mean there's no clock going to pin M9 or that your design doesn't do anything? Assuming the latter - the 'set_location_assignment' is all you need to ensure your design knows where to source it's clock from. Arguably you should also tell Quartus what signalling standard of the clock (2.5V for this clock on this board), although not adding this won't stop it working. I think it's more likely that you haven't got something connected up correctly in your design. Is it written in verilog or VHDL? Can you post some code? Cheers, Alex
