11 years agoUser how to communicate with Qsys with PCIe?
I'm studying Altera PCIe solution, and the Qsys design flow should suit for fresh man like me. I looked several examples, and found that all of them don't open interface to user logic, as attached im...
11 years ago --- Quote Start --- Hi Jerry, you receive data trough the RxM_BAR interface when you look at page 17 in ug_pcie_avmm_dma . RX --> PCIe BARs. 1. Just go trough some user guide and examples and try to understand how the PCIe IP cores interfaces work and understand what the examples do. The user guide helps a lot. 2. Then you have to align your user design to these existing IP cores. (When you work in a company draw an blockdiagramm first..its always good) --- Quote End --- Thanks a lot! I will look into user guide and example firstly!
