use the -2008 switch to vcom to unable(vcom-1436)
error
vcom Message # 1436:
# VHDL 1993 through VHDL 2002 allowed an expression to be associated with
# a formal port in a port map as long as the expression was globally
# static and the port was of mode IN. VHDL 2008 now allows non-static
# expressions as well. Use the -2008 switch to vcom to enable this
# feature.
How can I switch to -2008?
- ShengN_altera
You can do like this vcom -2008 <your_file.vhd>
Or you can edit the modelsim.ini by doing this VHDL93 = 3 / 2008
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
- ShengN_altera
Modelsim or Questa:
Compile > Compile Options > VHDL > Use 1076-2008
Right clicking on the files > Properties > Project Compiler Settings > VHDL > Language Syntax > Use 1076-2008
Nativelink:
Go to [ Settings | Compiler Settings | VHDL Input ] and select [ VHDL 2008 ]
Sheng
- ShengN_altera
Any further consideration on this thread?
- ShengN_altera
Since there are no further feedback for this thread, I shall set this thread to close pending. If you still need further assistance, you are welcome reopen this thread within 20days or open a new thread, some one will be right with you.
