SBuhr
7 years agoUse Testbench Template Writer for a single source file
Hi, the Testbench Template Writer of Quartus works fine. But it just works fine if it is used inside a project. Is there any way to generate a testbench template for just any vhdl file (without the...
CalvinJoaz_P_Intel
Contributor
7 years agoHi Simon,
Looks like Testbench Template Writer cannot be used as standalone. You still have to create project to run it because the writer takes the Netlist of the design and use it to write out the template testbench.
So we still need the Quartus Project to use the Testbench template writer.
Thank you.
