NuvKFC
Contributor
5 years agoUse script to open SignalTapII in Linux system
How to use script to open SignalTapII GUI, and use this SignalTapII GUI to add node, configure trigger signal, do re-compiler, and so on. Thank you very much.
I had try to use quartus_stp command,...
sstrell
5 years agoI think the difference is that for the first situation, you have your project open in the Quartus GUI. When you run quartus_stpw from the command-line, that's the standalone Signal Tap tool used if you don't have a full Quartus installation running. I think you want to be using quartus_stp, not quartus_stpw.
- NuvKFC5 years ago
Contributor
Hi sstrell, I get it. Thank you very much.
But how to use quartus_stp command to open SignalTap II GUI that the user can use the SignalTap II GUI to double-clicking to add nodes?
I can't find any command to do that.
I think most user need Node Finder in the SignalTap II GUI for adding new signals as soon as possible.
