11 years agouse an entity in process
I write four VHDL file 1) 1 bit full adder 2) 8 bit full adder 3) 1 bit flip flop 4) accumulator 1 and 2 and 3 is correct and I tested those , but I have a really big problem in accu...
11 years agoI change accumulator VHDL code , but when I make it's wave form it litte wrong!
(I add few line to other section too!) there are codes: 1) 1 bit full adder Library ieee; Use ieee.std_logic_1164.all; --------------------------------------------------------------------------- Entity fullAdder is port( CLK : in std_logic; Cin : in std_logic; x : in std_logic; y : in std_logic; s : out std_logic; Cout : out std_logic ); end fullAdder; Architecture fullAdder_logic of fullAdder is begin process(CLK) begin if rising_edge(CLK) then s <= x xor y xor Cin; Cout <= (x and y) or (x and Cin) or (y and Cin); end if; end process; end Architecture; ------------------------------------------------------------------------------------------------------------------------------- 2) 8 bit adder Library ieee; Use ieee.std_logic_1164.all; Use work.all; --------------------------------------------------------------------------- Entity eightBitAdder is port( CLK : in std_logic; Cin : in std_logic; x : in std_logic_vector(7 downto 0); y : in std_logic_vector(7 downto 0); s : out std_logic_vector(7 downto 0); Cout: out std_logic ); end eightBitAdder; Architecture eightBitAdder_logic of eightBitAdder is component fullAdder port( CLK :in std_logic; Cin,x,y : in std_logic; s,Cout : out std_logic ); end component; signal carry : std_logic_vector(8 downto 0); begin carry(0) <= Cin; gen_add: for i in 0 to 7 generate lebel_fulladd: fullAdder port map (CLK, carry(i), x(i), y(i), s(i), carry(i + 1)); end generate gen_add; Cout <= carry(8); end Architecture; ------------------------------------------------------------------------------------------------------------------ 3 ) 1 bit flip flop library ieee; use ieee.std_logic_1164.all; entity D_ff is port ( D: in std_logic; CLK: in std_logic; RST: in std_logic; Q: out std_logic ); end D_ff; architecture D_ff_logic of D_ff is signal ff_state: std_logic; -- This will hold flip flop state begin process(CLK) begin if rising_edge(CLK) then if RST='1' then ff_state <= '0'; -- Reset, change state to 0. else ff_state <= D; -- 'clock' in input. end if; end if; end process; -- Output current flip flop state Q <= ff_state; end architecture; ------------------------------------------------------------------------------------------------------------------------------ 4 ) accumulator library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity accumulator is port ( Input: in std_logic_vector(7 downto 0); CLK: in std_logic; Output: out std_logic_vector(7 downto 0) ); end entity accumulator; architecture accumulator_logic of accumulator is component D_ff is port ( D: in std_logic; CLK: in std_logic; RST: in std_logic; Q: out std_logic ); end component; component eightBitAdder is port( CLK : in std_logic; Cin : in std_logic; x : in std_logic_vector(7 downto 0); y : in std_logic_vector(7 downto 0); s : out std_logic_vector(7 downto 0); Cout: out std_logic ); end component; signal DFF_AC: std_logic_vector(7 downto 0); signal ALU_out: std_logic_vector(7 downto 0); signal overFlow: std_logic; signal cout: std_logic; begin --DFF_Ac0: D_ff port map ( '0', CLK, '1', DFF_AC(0)); --DFF_Ac1: D_ff port map ( '0', CLK, '1', DFF_AC(1)); --DFF_Ac2: D_ff port map ( '0', CLK, '1', DFF_AC(2)); --DFF_Ac3: D_ff port map ( '0', CLK, '1', DFF_AC(3)); --DFF_Ac4: D_ff port map ( '0', CLK, '1', DFF_AC(4)); --DFF_Ac5: D_ff port map ( '0', CLK, '1', DFF_AC(5)); --DFF_Ac6: D_ff port map ( '0', CLK, '1', DFF_AC(6)); --DFF_Ac7: D_ff port map ( '0', CLK, '1', DFF_AC(7)); adder: eightBitAdder port map(CLK, '0', std_logic_vector(Input), std_logic_vector(DFF_AC), ALU_out,cout); DFF0: D_ff port map ( ALU_out(0), CLK, '0', DFF_AC(0)); DFF1: D_ff port map ( ALU_out(1), CLK, '0', DFF_AC(1)); DFF2: D_ff port map ( ALU_out(2), CLK, '0', DFF_AC(2)); DFF3: D_ff port map ( ALU_out(3), CLK, '0', DFF_AC(3)); DFF4: D_ff port map ( ALU_out(4), CLK, '0', DFF_AC(4)); DFF5: D_ff port map ( ALU_out(5), CLK, '0', DFF_AC(5)); DFF6: D_ff port map ( ALU_out(6), CLK, '0', DFF_AC(6)); DFF7: D_ff port map ( ALU_out(7), CLK, '0', DFF_AC(7)); process(CLK) begin if rising_edge(CLK) then Output <= DFF_AC; else overFlow <= cout xor DFF_AC(7); end if; end process; end architecture; --------------------------------------------------------------------------------------------------------------------- if give input(00000001) to accumulator and draw wave form it work's but a little wrong!
