16 years agoUSB BLaster !!!quartus not detecting usbblaster
can any one please help me out here...
My USB Blaster is not shown in programmer window i am using Quartus2 9.1sp2 de1 kit os : vista 32 bit... i installed the driver from drivers/usb-blaster of quartus folder whenever i plugin usb ....device manager shows as Altera USB Blaster.. driver is signed driver....everything seems to be fine....but my programmer does not recognize usb blaster... i tried installing a seperate programmer from altera ...but the same result ...it does not recognize usb.... i tried every single options running programmer in xp compatability mode.... ....installing even 7.2 quartus...but no luck... thanks for your help14 Replies
--- Quote Start --- Oh my God, I wasted more than 8 hours on this problem, and finally I solved it. *************************************************** The trick is......as adviced by FluxCapacitor to run the software "as Administrator" even if you have Administrator priviliges!!! *************************************************** I do not know who to blame...the Windows team or the Altera team?! Any way, it is good to spread this bug and its solution for the future users of Quartus II software Special thanks to FluxCapacitor:cool: --- Quote End --- Your welcome. Glad to hear it worked for you too! :D I don't think this is any fault of Altera's as such. It something that I have had to do for a number of apps that I run to function correctly. Being device related it must be calling a system DLL that requires some degree of access not associated by the win 7 administrator. Hopefully the Quartus developers can look at what is causing it and circumvent the security level requirements somehow. - Altera_Forum
--- Quote Start --- Your welcome. Glad to hear it worked for you too! :D I don't think this is any fault of Altera's as such. It something that I have had to do for a number of apps that I run to function correctly. Being device related it must be calling a system DLL that requires some degree of access not associated by the win 7 administrator. Hopefully the Quartus developers can look at what is causing it and circumvent the security level requirements somehow. --- Quote End --- Thank you for the solution! Running the tool as an administrator did the trick. For future installs of Quartus versions, instead of just double clicking the setup file, right click the file and run as administrator. This may solve the problem, and there wouln't be any need to constantly open quartus as an administrator. - Altera_Forum
I notice you are using a 32 bit version of win7. This means you need a 32 bit version of jtagserver.exe installed as a service and running properly.
Please run the command `<full-path-to>/quartus/bin/jtagserver.exe --install` - you may have to uninstall first if you have the wrong one running. After running this use `jtagconfig --debug` to check it can access your blaster. Newer versions of jtagserver should work with old jtagconfig (and vice versa) so I normally just install the newest one available. If you don't have admin access and don't have an installed jtagserver then jtagconfig (or any of the other tools) should try and run a temporary jtagserver, this one will work mostly the same but won't support remote jtag. - Altera_Forum
device type=3
vid pid type=2in the ftdi deivce re-program what is device type 3 and vid pid type 2.. actually in device type it shows different ftdi devices and vid pid type- 3 options 1. default 2. only pid 3. vid and pid..
so please tell which to select..
one more question: i tried to change these settings, it is getting detected and programmed as usb blaster, but i am not able to program/ configure through it..
error in quartus: unable to establish jtag chain (do you think tck speed is the issue?)
thanks,
mahesh
