11 years ago --- Quote Start --- I have tried on other's PC, the same "Unknown Device" issue prevails. --- Quote End --- Ok, at least that confirms the hardware has an issue. Do you have a USB-Blaster stand-alone cable? There is a JTAG header on the board. Try connecting directly to that and detecting the JTAG chain. You will have to consult the DE2-115 User Manual to see if there is a switch setting or jumper that needs to be changed to select the JTAG header. Cheers, Dave
