11 years ago --- Quote Start --- That does sound like a hardware issue. The general rule for hardware problems is; 1. Check power supplies 2. Check clocks So, go look at the DE-115 schematic and start checking the power supplies. Actually, in your case, first check the DE-115 with a different PC, just in case the one you are using has a bad USB connector. Cheers, Dave --- Quote End --- I have tried on other's PC, the same "Unknown Device" issue prevails. I am now looking at the schematics right now. At the same time, I have also contacted terrasic support, I hope I can get a technician to fix it if it comes to the worst scenario. Thank you for your time.
