USB Blaster not being installed after fresh installation of Quartus Prime software
- 4 years ago
So the installation of Quartus Prime Lite was uninstalled and then re-installed. I have attached two images to this post to give information about the installation. The first image was the for the Devices selected. I selected all the devices to be safe.
The second image is to show that I checked to Launch USB Blaster II driver installation.
The third image is to show that the Driver installation was successful. The response was for JTAG and not for the USB Blaster II driver though.
I still had to go in manually, per the procedure you attached your first post, fix the driver issues. (done in device manager)
I think there is something wrong with the installation software. I don't believe I should have to go in and manually do anything.
Any thoughts?
Devices
Driver installation checkedDriver installation confirmation
Hi Novice,
Thank you for reaching out. Regarding your raised concern, there's might be a conflict between the USB-Blaster II driver and other 3rd party drivers on your PC that probably causing this.
You may want to take a look at the following related KDB which explaining further regarding this problem.
Why is my USB Blaster II not detected by Quartus II on Windows?
Why does the Intel® FPGA Download Cable II driver installation fail on Windows* operating system?
Hope this answer your question.
Fakhrul
Thanks for the references.
I was installing Quartus Prime Lite software which is free. I don't think a digital certificate is required. It wouldn't make any sense however it may be possible.
