9 years agoUSB Blaster II will program but not verify, but USB Blaster will....
I have both the USB Blaster and USB Blaster II. We've been using the Blaster II due to the faster programming speeds. But for some reason I cannot get multiple different and similar boards to progr...
9 years ago --- Quote Start --- We're using a Stratix III EP3SL1501152C2N and the EPCS64SI16N to program over active serial. --- Quote End --- Your latest findings in post# 4 suggest a software problem, without this observations I had guessed about a signal quality problem. AS programming interface is quite sensitive to ringing DCLK, a faster clock driver in USB Blaster II might cause it.
