9 years agoUSB Blaster II will program but not verify, but USB Blaster will....
I have both the USB Blaster and USB Blaster II. We've been using the Blaster II due to the faster programming speeds. But for some reason I cannot get multiple different and similar boards to progr...
9 years agoAnother couple of interesting points (or not...) is that after the device is programmed with the USB Blaster, I can switch to the USB Blaster II and perform a verify and it verifies successfully. I can also perform the "Examine" function with the USB Blaster II and it reads back the correct check sum. Finally I can Program and Verify (as long as it is the same file/checksum) and it works successfully. As soon as a new file with a different checksum is loaded, the Program / Verify function does not work on the USB Blaster II
