9 years agoUSB Blaster II not recognized in CentOS 7
Hello there, I am having an issue regarding the Max 10 Development Kit where I installed the drivers and set it up according to this url: "https://www.altera.com/support/support-resources/downl...
9 years ago --- Quote Start --- Did you happen to figure this out? Does anyone else have any idea on what could be going wrong here? I'm currently dealing with the same issue. Thanks --- Quote End --- Hello there, There was some problem with the permissions and acess to the USB interface. The strange thing here is that for some reason the interface started to function normally after a day or so. I think I needed to restart the computer (the problem here is that it was a laboratory computer that I did not had root access). After a while it started to work properly, but then, I did not no what could have triggered this errors. Regards,
