9 years agoUSB Blaster II Active Serial Programming Issues
Hello, We have recently upgraded our programming cables from the USB Blaster to the USB Blaster II. We have installed the drivers without issue and are running Quartus Prime 16.0. JTAG programm...
8 years ago --- Quote Start --- Hello, We have recently upgraded our programming cables from the USB Blaster to the USB Blaster II. We have installed the drivers without issue and are running Quartus Prime 16.0. JTAG programming is successful, and verification is successful too, but not after first having to step the frequency from 500kHz all the way back up to 24MHz. However, when we try and program through the Active Serial mode, the quartus programmer gives the error message "Active Serial programming not supported with currently selected hardware". After reviewing the documentation, it appears the Blaster II should be able to support this. Does anyone have any idea what is going on or how to fix this issue? Thanks --- Quote End --- Any update for this thread? I have same problem with Quartus v13 sp1, USB-Blaster II and Active Serial mode. Thanks, ATS_
