9 years agoUSB Blaster II Active Serial Programming Issues
Hello, We have recently upgraded our programming cables from the USB Blaster to the USB Blaster II. We have installed the drivers without issue and are running Quartus Prime 16.0. JTAG programm...
9 years ago --- Quote Start --- It should be supported according to USB Blaster II manual. May be a Quartus bug. I wonder why you are still using AS programming mode although AS flash can be much easier programmed though indirect JTAG programming method, without a dedicated connector? --- Quote End --- Hi FvM, What configuration mode do you recommend for user? Acutually, we are also using AS mode in our system. For it's simple and low cost.
