mwdawson-tfs
5 years agoUSB-Blaster driver install for Quartus Prime v20.1.1 failing
The driver install errors showed up during the install process. I went in later and used device manager to update the driver manually. It still refused to install drivers and reported errors. I track...
YuanLi_S_Intel
5 years agoCan you check if you directory is selected correctly? I have tested on my side, seems like no problem
