mwdawson-tfs
5 years agoUSB-Blaster driver install for Quartus Prime v20.1.1 failing
The driver install errors showed up during the install process. I went in later and used device manager to update the driver manually. It still refused to install drivers and reported errors. I track...
YuanLi_S_Intel
5 years agoHi Svigil,
For USB Blaster I / II, you may find the information at link below:
Bruce
SVigil
5 years agoThanks Bruce. Now the problem I'm having is the patch will not install. I'm trying to fix a stand alone programmer installation, and it says there is no stand alone programmer install in any directory I try. See attached screen shot of the attempt of trying the directory with the main executable in it. Can you tell me which I need to select?
