mwdawson-tfs
5 years agoUSB-Blaster driver install for Quartus Prime v20.1.1 failing
The driver install errors showed up during the install process. I went in later and used device manager to update the driver manually. It still refused to install drivers and reported errors. I track...
YuanLi_S_Intel
5 years agoHi mwdawson-tfs.
Yes, you can find USB Blaster driver at link below:
Hi SVigil,
Yes, it needs to be at the moment. You may follow the method as listed below to update the digital signature certificate.
Bruce
SVigil
5 years agoThank you. I will resort to buying Blaster II cables if I must. But is there a similar certificate fix for the USB Blaster Cables? I already purchased two USB Blaster for $600. The current drivers that are causing the problem came from the Quartus Programmer 20.1.1.720 downloaded last week. Does this release contain the most up to date drivers?
