USB-Blaster driver install for Quartus Prime v20.1.1 failing
Hi mwdawson-tfs.
Yes, you can find USB Blaster driver at link below:
Hi SVigil,
Yes, it needs to be at the moment. You may follow the method as listed below to update the digital signature certificate.
Bruce
- SVigil5 years ago
Thank you. I will resort to buying Blaster II cables if I must. But is there a similar certificate fix for the USB Blaster Cables? I already purchased two USB Blaster for $600. The current drivers that are causing the problem came from the Quartus Programmer 20.1.1.720 downloaded last week. Does this release contain the most up to date drivers?
- sstrell5 years ago
Unfortunately, your first link does not have the driver for download on that page, just instructions for installing it. You still have to download the full Quartus to get the driver, which is weird.
