mwdawson-tfs
5 years agoUSB-Blaster driver install for Quartus Prime v20.1.1 failing
The driver install errors showed up during the install process. I went in later and used device manager to update the driver manually. It still refused to install drivers and reported errors. I track...
YuanLi_S_Intel
5 years agoHi,
Can you try to install by following the below guide?
Bruce
SVigil
5 years agoYuan,
I had this same issue with the USB blaster cable, and found the below work around. It seems there is a signature security issue with the usb blaster driver. My question is, if I buy a USB blaster II cable for $225 does it have a proper signature in the driver? My IT department at my company does not want to install a driver that doesn't have a signature.
Solution: You first have to disable driver signature enforcement. This is the sequence:
1 - Go to windows 10 settings and search for "advanced startup options" 2 - Under Advanced startup, hit "Restart now" 3 - After a moment, you'll get a "choose an option" screen - choose "Troubleshoot", then "Advanced options", then "Startup Settings" 4 - You'll get a screen telling you what you will be able to change and a single "Restart" button - press it. 5 - If your boot drive is BitLocker encrypted, you'll need to enter the recovery key (press return, enter the key in the text box then hit return again - it took me three goes to realize I had to hit return before I could enter they key !) 6 - You'll be given a menu of options, number 7 disables driver signature enforcement 7 - When the PC restarts, use Device manager to update the drivers - this time you'll get a warning about the signature, but they install fine. 8 - When you've finished, restart normally to re-enable signature enforcement
