JHebe3
7 years agoUSB Blaster device is not recognized by Quartus Programmer
Using Quartus II 32-bit ver 12.0 on Windows 7. I believe I have installed the usb blaster driver correctly, USB-Blaster displays correctly under Control Panel>Devices and Printers. But usb blaster ...
Vicky1
7 years agoHi,
Please check the below things once again,
- Ensure that USB Blaster Adapter connected to the board in correct manner(one to one mapping)
- Check with the same USB Blaster with another system
- If possible try with another USB Blaster with same system.
Vikas
- JHebe37 years ago
Vicky,
I have tried the USB blaster device (Altera board) with another system and it was successful.
However, using the same device on my own system, the issue persists with no change!
I do not currently have access to another usb device.
However I feel that the issue is with my system/configuration as the device works with another computer.
Please help, what else can i do to fix this issue?
