JHebe3
7 years agoUSB Blaster device is not recognized by Quartus Programmer
Using Quartus II 32-bit ver 12.0 on Windows 7. I believe I have installed the usb blaster driver correctly, USB-Blaster displays correctly under Control Panel>Devices and Printers. But usb blaster ...
Vicky1
7 years agoHi ,
I believe that, you could have checked this, but just to ensure that "Currently selected hardware" drop-down menu as attached,
Please refer the below KDB link & let me know how it works in this case,
Vikas
- JHebe37 years ago
Thanks Vikas
To clarify, the Programmer shows No Hardware selected. In the Hardware Setup, the Currently Selected Hardware shows No Hardware, as you attached, and there is no USB blaster option in the drop down menu, as you showed. There is also no USB blaster (or anything) under the Available Hardware Options.
I did check the KBS page you suggested, but I do not see any Altera JTAG Server running on my system services
Is there something else that I can do to fix this issue?
