Andrew_G_
5 years agoUSB Blaster - Install failed. 20H2 ?
Hi, I have a consistent issue when trying to install the USB-Blaster drivers on Windows 10, 20H2
This is using the 20.1.1 version of Quartus Prime
Running dpinst.exe gives a "cannot complete the ...
- 5 years ago
My understanding on the issue is that, you are having issue to install USB Blaster driver on windows. Please let me know if my understanding is not correct.
You may refer to the guide below for USB Blaster installation on Windows:
Bruce
raspopov
4 years agoAn USB Blaster driver catalog (.cat) has been signed by chain of two outdated certificates, the one expired in the Jun 2021 and the second in the Jan 2021. The driver itself (.sys and .dll) are OK. Windows 10 64-bit can't add such driver to the driver store without a properly signed .cat-file especially with the Secure Boot activated. As a temporary workaround for this case or the future problems you can simply set the current time prior to Dec 2020 and the install will works again.
