USB Blaster - Install failed. 20H2 ?
- 5 years ago
My understanding on the issue is that, you are having issue to install USB Blaster driver on windows. Please let me know if my understanding is not correct.
You may refer to the guide below for USB Blaster installation on Windows:
Bruce
Bruce
This procedure does not work. I am using Win 10 Pro, USB Blaster and "intelFPGA_lite 20.1.1 quartus drivers usb-blaster" after applying the patch. Device Manager shows "Unknown USB Device (Device Descriptor Request Failed)
I suggest you install Quartus 20.1.1 lite , attach a USB Blaster and see if it appears in the Quartus programming window.
Right now I can not program an Intel FPGA. Perhaps I should try using a Xilinx part.
