Andrew_G_
5 years agoUSB Blaster - Install failed. 20H2 ?
Hi, I have a consistent issue when trying to install the USB-Blaster drivers on Windows 10, 20H2
This is using the 20.1.1 version of Quartus Prime
Running dpinst.exe gives a "cannot complete the ...
- 5 years ago
My understanding on the issue is that, you are having issue to install USB Blaster driver on windows. Please let me know if my understanding is not correct.
You may refer to the guide below for USB Blaster installation on Windows:
Bruce
Andrew_G_
5 years agoUpdate. Tried dpinst.exe on a 1909 VM and I get the APU_USB and oemsetup.inf failing to install but the Altera USB-Blaster Device and JTAG parts go in OK with a cheery "ready to use" status.
I can't check with the MAX10 hardware as this VM doesn't have USB pass-through. I'll try with a proper 1909 machine later.
