11 years agoUSB 3300 PHY not showing up on DE1-SoC board.
Hello All,
I was trying to get some data to pop up over the 3300 (http://www.microchip.com/wwwproducts/devices.aspx?product=usb3300) USB phy. And was finding the .QSF file was incomplete, so I assigned the pins at 3.3v LVTTL. and used..
module Phytherface (
input clock,
input direction,
input readline,
inout uart,
output writeline
reg a;
reg b;
assign uart = direction ? a : 8'bz;
assign writeline = b;
always @ (posedge clock)
begin
b <= uart;
a <= readline;
end
in conjunction with.
Phytherface AK01 (.direction(HPS_USB_DIR),.clock(HPS_USB_CLKOUT),.uart(HPS_USB_DATA),.writeline(take));
wire take;
takeone TK01 (.in(take),.out (HEX5)); /*<-- posedge sample&hold*/
endmodule
But no go, Did I do something obviously wrong (with the tristate?)?13 Replies
If you want usb simple and fast add a ft232h ic
--- Quote Start --- Cyclone V SOC has inbuilt USB Controller which supports ULPI Interface. That USB controller uses that USB PHY chip. --- Quote End --- If you're not going to tell what it's going to be that's causing it, you're just spamming the topic. Thats why I brought up the link to the area I'd like to move into twice. Since that topic sank into oblivion again.. Which may well have had the potential to save me a day of work. I don't know what the problem would be. So does it mean the chip is misconfigured by default to recieve "is what im doing" a byte of data from whatever device, (that may well be a computer slave,or a MIDI controller master) ? And if so why? Seeing I don't think I would "have" to start feeding it headers, since it provides it's own clock. - Altera_Forum
I'm using DE1-SoC board with linux console provided by Terasic. what should i do to change the USB Host mode to USB peripheral mode ? I know that i have to short the ID pin of usb3300 PHY to V3.3. But i don't know if i have to do some software modifications. The idea is to make my board act as a device and establish a communication between the PC and the board. ps: sorry for my bad english
