11 years ago
USB 3300 PHY not showing up on DE1-SoC board.
Hello All,
I was trying to get some data to pop up over the 3300 (http://www.microchip.com/wwwproducts/devices.aspx?product=usb3300) USB phy.
And was finding the .QSF file was incomplete, so I assigned the pins at 3.3v LVTTL.
and used..
module Phytherface (
input clock,
input direction,
input  readline,
inout  uart,
output writeline
reg  a;
reg  b;
assign uart = direction ? a : 8'bz;
assign writeline = b;
always @ (posedge clock)
begin
b <= uart;
a <= readline;
end
in conjunction with.
Phytherface AK01 (.direction(HPS_USB_DIR),.clock(HPS_USB_CLKOUT),.uart(HPS_USB_DATA),.writeline(take));
wire take;
takeone TK01 (.in(take),.out (HEX5)); /*<-- posedge sample&hold*/
endmodule
But no go,
Did I do something obviously wrong (with the tristate?)?
    --- Quote Start ---
    Cyclone V SOC has inbuilt USB Controller which supports ULPI Interface. That USB controller uses that USB PHY chip.
    --- Quote End ---
    If you're not going to tell what it's going to be that's causing it, you're just spamming the topic. Thats why I brought up the link to the area I'd like to move into twice. Since that topic sank into oblivion again.. Which may well have had the potential to save me a day of work.
    I don't know what the problem would be. So does it mean the chip is misconfigured by default to recieve "is what im doing" a byte of data from whatever device, (that may well be a computer slave,or a MIDI controller master) ? And if so why?
    Seeing I don't think I would "have" to start feeding it headers, since it provides it's own clock.
    I'm using DE1-SoC board with linux console provided by Terasic. what should i do to change the USB Host mode to USB peripheral mode ? I know that i have to short the ID pin of usb3300 PHY to V3.3. But i don't know if i have to do some software modifications. The idea is to make my board act as a device and establish a communication between the PC and the board.
    ps: sorry for my bad english
